Salvo
May 13, 2015Explorer
If you use 12V panels with Eco W then it's OK to switch to pwm during abs. There may be a 5 - 10% drop in current. But if 24V panels are used then Isc is half as much and therefore pwm current is drastically reduced. Not good.
As far as I'm aware, no other mppt controller does that.
red31 wrote:Salvo wrote:
I read in the Eco W manual that it only operates in mppt mode during bulk. In other words, during abs it goes to pwm mode. Is that what you see?
How would they see that? They report as much as double Isc in abs/float, so bucking is going on but not MPPT?
