pianotuna
Apr 02, 2014Nomad III
Hi,
This is all a balancing act. The higher the voltage the less efficient the MPPT is. But the hotter it is--the higher you wish the panel voltage to be. The sooner in the day voltage is above 14.8 (for example) the sooner charging happens.
Does the amperage stay the same as the voltage drops from heat?
Does higher design voltage allow for better shading results? (I'm talking general shade of the entire panel.)
What will happen if BFL13 uses his PWM vs MPPT in the shade on the 230 watt high voltage panel? Which will outperform the other?
