Canadian_Rainbi
Feb 01, 2017Explorer
pianotuna wrote:
CR,
Any idea what the line voltage is when running the heat pump? Perhaps the Sola is boosting from 100 volts?
The lowest we have seen it today was 107, when the heatpump was running BOTH compressors, drawing 26 Amps. At the moment it's at 126V. If I were to put the Sola Boost on it would drop to about 112. Which is where it was yesterday with a line voltage of about 127.
Thanks to Mexican wiring, there is a 15A duplex outlet along side of and on the same 30A breaker as the 30A outlet so I can have the power cord to the rig and a plug in analog volt meter on at the same time.
