3_tons
Jan 22, 2023Explorer III
bdosborn wrote:
It seems like you're confusing my post with Don's, I didn't say anything about a "calendar-scheduled approach…".
The Battery Management System (BMS) in all LiFePO4 batteries has a cell balancer built into it and it works every time the battery is charged completely. Some batteries (like Battleborn) need an absorption stage to give the balancer more time to work; they typically only balance at 500mA so it can take awhile. Its transparent to most battery owners unless they have a BMS that displays battery cell voltages.
Its all in the specs of the battery you buy, if it doesn't say anything about an absorption stage then you….
Bruce
Not intended, I was merely speaking to the broader audience, primarily revisiting the so-called every 30 day approach which Don had mentioned (Don has once before stated “every 7 days” applies…(FWIW, I disagree)…Yep, the balancing phase (at 14.x volts, whatever phase one opts to call it…) is relatively transparent - this is why I always recommend a Smart-Shunt so one can observe the occurrence and completion of re-balancing…Depending on the several previous variables I’d mentioned, this can take from several minutes to say roughly 20 min or so, often depending on battery capacity…
3 tons
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
