doughere
Apr 22, 2014Explorer
BurbMan wrote:Wayne Dohnal wrote:
With all those disclaimers, the general result was that the load level didn't make a whole lot of difference in fuel consumption.
1,600 watt load: Run time 2.97 hours/gallon. 4.75 kWh/gallon, RPM = 4,300
465 watt load: Run time 8.92 hours/gallon. 4.15 kWh/gallon, RPM = 3060
555 watt load: Run time 8.06 hours/gallon. 4.47 kWh/gallon, RPM = 3150
What am I missing here....yes, the EFFICIENCY stays pretty constant at 4.xx kWh/gal, but the CONSUMPTION varies with the load according to your results, ie, the 1600w load uses 3x the fuel compared to the 465 watt load.
I don't think you're missing anything. The question was how to get the most watts per gallon; loaded or not. Seems that it doesn't make much difference. Efficiency is more or less constant, you'll use fuel in direct relationship to the wattage you use.
Regards,
Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
