KerriExplorerApr 06, 2014Elec. hot waterI just started to open up our Octane Jayco toy hauler and was ready to check the water lines and hot water tank. Lines look good and flushed fine. Filled the water tank and then flipped the switch for...Show More
pugslyyyExplorerApr 06, 2014Did you remove the element to drain the water heater when you winterized? If so maybe it's not hooked back up.(My electric element is that way)
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentNo flow from hot water tank Nautilus P1 systemHot water heater question .....Hot water problemClass C Elec Hot Water upgrade...Hot Water Replacement
