I just started to open up our Octane Jayco toy hauler and was ready to check the water lines and hot water tank. Lines look good and flushed fine. Filled the water tank and then flipped the switch for...
Check AC circuit breaker ON Check rocker switch in outside compartment ON Check the t-stat reset.push in to reset. Electric t-stat is left one in outside compartment.
IF Atwood.... Check AC circuit breaker ON (No reset on t-stat....plus electric/gas use same set and gas worked)
IF still no electric then you need to check that there is 110V AC power thru the element
