Dick_B
Apr 22, 2014Explorer
If you can get to the heating element put a volt meter on the terminals to see if it is getting power. If it is then the element probably needs replacing.
If there is no power the problem is bigger and will require quite a bit more investigation to solve it.
I recently had to pull my heater completely out of the rig to replace some fried wiring. Let's hope it is just the element.
For immediate help search this Forum for `water heater' then search the results for `element' and pick and choose the posts.
