mlj427's avatar
mlj427
Electric brakes
I just bought a 2000 Haulmark enclosed trailer and need to get it through inspection. It has a small breakaway battery on the tongue of the trailer and a deep cycle battery inside both are bad. If I just replace the deep cycle battery what wiring changes do I need to make? Any suggestions will be appreciated.
Thanks
Mike
  • mlj427 wrote:
    Yes the small battery is the emergency power but I was wondering about just using a deep cycle battery.
    Yep, If you can wire the E brake to the main battery. Good to go.
  • Yes the small battery is the emergency power but I was wondering about just using a deep cycle battery.
  • The small battery is probably your emergency brake power, so its likely all you need.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
