Y-Guy
Mar 30, 2022Moderator
I'm not sure which connectors you have. On my Motorhome I have a 7-pin connector on my Jeep its a 4-pin connector so my wire has both 7-pin and 4-pin on the other side. If you google "7-pin wiring diagram" or "4-pin round wiring diagram" etc. you should find the schematic you need to test to see if the issue is with the connector or the wiring itself.
7-Pin RV Diagram
4-Pin RV Diagram
7-Pin RV Diagram
4-Pin RV Diagram
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
