Skibane
Mar 31, 2022Explorer II
^ Yep - Dielectric grease is good stuff.
If you put it on clean electrical contacts, it keeps them from being exposed to water - which prevents corrosion on them.
Putting it on corroded electrical contacts doesn't work nearly as well, since...well, they're already corroded.
The green Scotch-Brite dish scrubbing pads work great for removing corrosion on contacts. Finish up with concentrated rubbing (isopropyl) alcohol before applying the dielectric grease.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
