haydoracin
Feb 08, 2014Explorer
Electric Fireplace - Too Cold?
Making updates to MH and I wanted to replace the old CRT TV. It was mounted in the dash and the 32" flat screen would not fit in the existing area. Looked and looked for an electric fireplace to mount where the TV was and finally found one that was the correct width and depth but too tall. Decided I could modify the cabinet so it would fit and I was successful with the modification. After the installation I was very pleased and the fireplace worked great when I took it from the warm house and installed in the MH. The next day I went to the MH and the interior temp was in the 20s. When I turned on the fireplace it started making noise and the display flickered. My question is was the temp too cold for the display function of the fireplace? Will it need to be "warmed Up' like a flat screen TV or computer before it can be turned on? This particular fireplace the display can not be turned off separate from the heat function. I plan to use it for auxiliary heat so I could run the furnace to warm things up before turning the fireplace on if necessary.
