rocmoc's avatar
rocmoc
Electric only working on Side 2 of inverter. FIXED!!!!
Same problem after installing a new inverter. Both sides of electrical works on pass-thu mode when hooked up to shore power. Switch over to invert and only side 2 works. This was the problem before installing a new inverter. Thought the old inverter was the problem as there was corrosion all thu the old inverter's boards & the electrical connections. The old inverter was tested at a local RV repair location and was told it was shot. I purchased a new (updated model) inverter (not from the repair location) and still have the same problem. HELP! Any ideas. Everything is great when hooked up to shore power but only side 2, Micro-wave & bathroom, works when not on shore power. Every outlet use to work!
Thanks,
rocmoc n AZ/Mexico
  • Aha!
    It's a CON-verter
    Not an IN-verter
    How to ask this so that 200 words are not needed in the question?
  • Could a GFI outlet work in pass-thu mode and shut the leg down in inverter mode if the GFI outlet is failing? Could the sine wave inverter be that sensitive?
    rocmoc n AZ/Mexico
  • rocmoc wrote:
    docj wrote:
    2oldman wrote:
    By 'both sides' I'll interpret that as both legs of a 50a circuit. OK..
    I'm a little behind on my 50a knowledge, but I do know it's two legs. So.. is that inverter designed for 2-120vac outputs? I've never seen a "50a" inverter.
    I realize that it's probably not worth speculating, but my MH had its inverter wired through a subpanel with two breakers. One of the breakers handled the microwave and an outlet or two and the other had everything else. If that second breaker tripped the effect would have been as the OP described it, but it wouldn't explain why everything works in pass-through mode.
    I'm as puzzled as everyone else; maybe the OP can provide more info.
    Yup have a second breaker panel but everything is working. Will check a third time just in case.
    rocmoc n AZ/Mexico
    Just checked, everything is good. Breaker panel is setup with a 50amp breaker that is marked Main (shuts everything down) and a 30amp breaker feeding the inverter. Everything else is fed thu the inverter except the frig, AC & washer/Dyer which are fed from the breaker panel.
    rocmoc n AZ/Mexico
    rocmoc n AZ/Mexico
  • There are two output sides, side 1 which is 20amp and side 2 that is 15amp. One in and Two out. Standard Holiday Rambler factory installation. I will check the output with a voltmeter tomorrow if I can find someone that has one. OR I will just switch the wiring between side 1 & 2. See what happens.
    rocmoc n AZ/Mexico
  • What are you using for a transfer switch? Is the inverter connected to both sides? Have you checked voltage going to both sides?
  • By 'both sides' I'll interpret that as both legs of a 50a circuit. OK..
  • Side 1? Side 2?
    Does this mean INCOMING 120vac shore power...
    And Side 2...
    Outgoing shore power OR inverter power?
    Honorable Chinee ahead getting themself. Putting horse behind cart. Build device, Sell device. Then find out instructions are Number 10
    Take some images and post or find a link to the manufacturer that has the photo interpretation of "Side 1 / Side 2"
  • A voltmeter directly on the output of the inverter is the first place I would stop,. Could have a bad new inverter or simply needs one of its circuit breakers reset.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
