tbax46's avatar
tbax46
Electric question
One leg of my 50 amp went out. Both sides of power post are good to go. Hooked up dog bone to 30 amp and both legs worked. Used a new 50 amp cord with twist connection adapter. Worked for a few days then one leg went out again.
sometimes the 50 is on and then it’s gone. Any of you electrical people have a possible answer.
  • When you are having problems, have to checked to see if you have a reading of 220-240V when inserting probes into the 2 hot connections? You should have 120V from either hot connection to ground but something close to 220-240V when probed between the 2 hots.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Happened to me once... History
    Original plug on 50 amp cord got nasty so I cut it off and grafted on another (Replacement plug properly applied to cord)
    One of the connections in the plug failed.
    IF I wiggled the plug (which you did when you switched to the dogbone) the connection would "Make" then later re-fail.
    Next stop was the shop for other reasons (Tools I don't have) and while the Technician did his thing.. I did mine with a brand new plug and the cord.. No further issues.
  • Btax,
    If I understand you correctly, you clearly have an intermittent (aka bad connection) that could be just about anywhere. It could be any where along the line.
    You changed to another cable and it worked for a while?
    Did you check the 50 at the post again?
    If any of your cables are not molded end, get out a screw driver and open them up and look for the bad connection.
    If you try to diagnose this with a "voltage" detector, that will drive you crazy because there will always be enough AC around to indicate power as there.
    Matt
  • Starting at the shore panel check all connections between there and your RV panel.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
