organcory97 wrote:
ScottG wrote:
The 120V breakers had nothing to do with it. You have a 12V auto-resetting breaker that is tripping for what ever reason and your problem is going to return.
I would find the 12V breaker and replace it (they're cheap). Otherwise you are going to get stuck someplace with the slide out.
The part will look something like these and you will need to get the amp rating off it: ***Link Removed***
Good luck,
Scott
Would there only be one of these auto resetting breakers?
Most often yes, they have just one but on rare occasions someone will install two in parallel.
I had one where they mounted the breaker under the trailer, next to the motor. Some others were mounted up near the front just behind the batterys. There are breakers designed to be installed in wet locations but they never seem to use them. Instead they use cheaper breakers designed to be installed inside. Those really dont do very well out in the weather and if they actually get road spray, they corrode.
Scott
