Curly2001
Dec 18, 2020Explorer II
Electric space heaters
Just curious if anyone has a good safe electric heater to use to heat a 30' fifth wheel overnight? Would like to supplement the propane furnace on colder nights.
Thanks,
Curly
Thanks,
Curly
pianotuna wrote:
My favorite heat source is electric heated carpets.
Bumpyroad wrote:pianotuna wrote:
Heat strips are useful down to about 40 f. If it is cold than that the air conditioner fans don't like it.
also, the semi warm air from the AC fan does not feel hot when it blows on you.
bumpy
Bumpyroad wrote:coolmom42 wrote:
I've always just used the basic little cube style heaters. They go to 1500 watts and 2 different fan speeds.
Don't use them with an extension cord or plug strip. Check that the tip-over cutoff works. Set them in a place where they wont' get pushed against anything cloth or plastic. They are perfectly safe.
I will add, don't set them on the floor next to the bed as they can scorch a circle on the blanket when/if it comes in contact. :)
bumpy
Curly2001 wrote:
I was also thinking about a heat strip in the A/C. We had an old Terry that had a heat strip and it was really good. Was old enough that we didn't have duct work but came out of the bottom of the A/C unit. Took the chill off and you didn't run the furnace. Do they still make them?
Curly
pianotuna wrote:
Hi,
I would avoid digitally controlled heaters. If the power "blips" they may turn off.
