Bipeflier
Mar 09, 2017Explorer
Oasisbob wrote:
I am at a stage in my vision loss where I need to admit I can no longer see well enough to do what I know how to do. I cannot see or feel well enough to use the adjuster hole on the backing plate so I remove the wheel each adjustment and reinstall. Well I just pulled the inner bearing past the seal and can not get it back. Time to admit defeat and turn it over to a professional. Funny thing is I cannot get the wheel back on to take it anywhere. Do I need to remove the seal, install the bearing and install new seal or is there another way? I am my own worst enemy at times. LOL
If you pulled the bearing through the seal that would leave the bearing still on the axle. At this stage, remove the seal and throw it away and replace AFTER removing the bearing from the axle and installing it into the hub.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
