theoldwizard1's avatar
theoldwizard1
Explorer II
May 30, 2019
Electric water heating
This is a question mainly for people with a 10 or 12 gallon water heater who frequently use shore power electricity to heat their water.
Most 120V heat elements are about 1500W so they are well less than a 15A draw. Has anyone installed a 2000W element or even a 240V 5500W (2250W @ 120V) element ? Both would require a 30A or 50A shore power connection AND some upgrades to the wiring (at least 12 gauge wire) and breaker inside your RV.
  • To change to 240V would be a lot of work as most if not all RV electric panels do not have 240 available. You would have to change to a house panel and then upgrade the wire from the breaker to the water heater
  • Hi,
    I'd rather go down from the 1400 watt. Recovery time is, for me, a non issue. I've used the propane side twice since 2009. I have a ten gallon unit.
    From ambient to first cycle takes about 90 minutes. If no water is drawn it appears to cycle every 4 hours and takes 15 minutes of "on" time.
  • OK to run on propane at the same time for fastest recovery. (assuming you have propane)
    Also there is an RV tankless W/H available for continuous hot water.
    I have not replaced the element.
  • Atwood uses a 1400W element......use to use a 1500W but went to 1400W to lower the amp draw
    Suburban uses a 1440W element
    RV Water Heater electric elements are fed by a 15A CB
    As you stated ....Wiring & CB changes would be necessary
    So NO....
    Doubt anyone has done that as it is not that much of an improvement (cost/benefit)
    1400/1440W element have a recovery time of roughly 6.2 gal/hr (based on initial 70*F water temp) ---even shorter time for reheat cycle (from 100*/110*F water temp)
    Want faster recovery time.turn electric & propane on at same time (16.2 gal/hr ---70*F water)
    Want hot all the time.....leave electric ON
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
