time2roll
Oct 19, 2013Nomad
To check continuity set the scale to ohms. Touch the leads together and you should get zero. Now set the thermostat to switch heat on and touch the leads to the terminals. You should get very close to zero ohms.
To check for voltage set to 20 vdc scale. Put the leads on the battery terminals and look for about 12.5 to 13.5 volts. Now move the lead to what you want to check. Make sure the ground is good or extend the lead all the way back to the battery if needed.
