sdetweil
Mar 22, 2015Explorer
MEXICOWANDERER wrote:
I asssssume the broken or missing screw is on the chassis frame rail?
If yes, that frame rail might prove to be a little to thick for a self tapping screw to work well.
Be sure whatever part of the frame you tap into to hold the ground wires that that frame member is not a separate piece of the frame which is riveted to the main frame rail. The ground wire must be connected directly to frame material: that is either the original large frame or a cross member that has been welded to the frame.
I picked up the habit of tapping holes in a frame rail with SAE threads from a tap I only use SAE thread bolts when connecting anything to a frame. Put an external tooth lock washer under the ground terminals then use the SAE bolt on top of that. then gob atop the bolt and the wire terminals or use undercoating spray.
Voice recognition works great if your vocabulary consists solely of "Hwang chow wah kee shan a day kong may fang toy". It sure as hell doesn't work worth ten cents with Inguish.
correct, the broken screw was into the main chassis rail. I have tap & die sets so can use one of those.. just wondering how much clearance I have on the other side of the chassis rail for drill and tap.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
