j-d
Mar 23, 2015Explorer II
Is that broken screw into what's like formed sheet metal forming the frame, or heavier duty material like angle iron or square tubing? Those have more thickness to hold onto your broken screw (or to resist drilling). The tip of the screw probably estends on the back side. Using penetrating oil, maybe heat, it's possible you could take vise-grips and continue to "drive" the screw till it came out the back side. If it's into tubing, no. Just drill/tap a new hole.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
