sdetweil
Mar 23, 2015Explorer
john&bet wrote:
Another thought would be to extend the wires to a spot where you don't have to worry about hitting anything on the back side. Then you can drill a hole and use a good bolt and nut.
yeh, can't get to the other side without a lot of work to drop the belly panel. On this side of the unit the belly panel is pinched between the chassis rail and the propane black pipe, which doesn't move.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
