Almot
Mar 23, 2015Explorer III
MEXICOWANDERER wrote:
A 1/4" X 28 SAE bolt will be fine. Take your time with the hole. Three drills in steps. Pilot, mid, then finish. Use a magic marker on the two remaining drills. Paint the depth using the pilot hole drill as a gauge.
Could you be less cryptic? :)
I think you are talking about bolt in a very thick metal where it doesn't come out on the other side, otherwise why worrying about proper depth? RV frames are - usually - not that thick.
Also, you keep on saying "bolt". But I don't see you mentioning any "nut" with this "bolt". Did you mean a bolt that cuts its own thread, like type B?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
