sdetweilExplorerMar 22, 2015electrical chassis ground screw brokenas I am finishing up the install of wiring to support my generator, I have noticed that the ground leads from the fuse panel and shore cord to the chassis are no longer connected.. the screw holding t...Show More
AlmotExplorer IIIMar 23, 2015OK, with water tank I see now the need for depth control. Back to the bolts - how do you drive a 1/4x28 bolt like This in a newly drilled hole in black steel that didn't have any screw in it before?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
Related ContentElectricInverter Chassis GroundTv inverter chassis groundIs one of your tie down tabs grounded?Electrical assistance
