Joe417
Apr 28, 2015Explorer
Cheapest route is 1/2 inch pipe insulation. A whole joint is about $2 and you can make a lot of them.
I cut off about 1 1/2 inches and put it around the cord. Cut around the outside of the foam about half way through so it will slide into the slot in the door.
If you don't like black or grey use a swim noodle with the color of your choice.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
