Bobbo's avatar
Bobbo
Explorer III
Jan 06, 2016
Electrical conundrum quiz
I have solved this problem, but thought the electrical experts might try their hand at diagnosing this problem.
My father in law made a homemade extension cord. He took a 12/2 wG cable and put a plug on one end. He wired a box with a SPST ON/OFF switch to the hot wire. He then wired the other end with a duplex 15 amp outlet.
When he plugged ANYTHING into the outlet, it would not work. It was like it had no power, so he called me. (I have a reputation of being able to fix anything.)
I plugged in one of the 3 light testers.
With the power switch turned ON, all 3 lights were lit.
With the power switch turned OFF, the red and middle lights were lit up which normally indicates a hot/neutral reversal, but the right light was not on. Note that this is with the power switch turned OFF.
Anyone care to guess?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
