shastagary
Jan 05, 2019Explorer
the plastic plug melted because of a bad connection or high resistance at that plug causing it to heat up and melt i do not think this happened all at once but over time from the high current draw of the microwave.
is there anything else on that wire in the circuit? wall outlets or any thing else in the slideout.
the fried converter had nothing to do with that plug melting if you were going to use another plug there i would use a 30 amp twist lock nylon plug.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
