larchambeau's avatar
larchambeau
Electrical Head Scratcher
I have been seasonal camping for a while, but recently encountered a puzzling event.
A little background, first. I have been in a site with 30-amp power, and it has been very stable and reliable. I also have fairly new battery, having been purchased May, 2015. Under normal circumstances, all systems run optimally.
A couple weeks ago, the CG experienced a short power outage. No problem, I'll run on batteries for a while till power is restored. But for whatever reason, I had no battery power, either. Power came back in a short time, so there was no cause to worry. But I did.
Since then, I've run a couple tests.
I turn off the breaker, and I have no lights anywhere in my unit. Using a meter, my battery is fully charged and appears capable of generating full output.
I checked all fuses and found none of them that I am aware of, to be defective. This includes all fuses in my main 12 volt box and two fuses in my converter.
But wait, while I have no lights in the trailer, I AM able to retract and extend my slideout. How is that possible? Is there something that prevents power from getting to my lights but allows the battery to work the slide?
Of course, all the lights that don't work on only the battery, work fine when my shore power is turned on.
What am I missing here? Do any of you have any ideas.
BTW, I am home for a few days and cannot test any of your ideas, but I will as soon as I get back out there.
  • Some also have a fuse in line or a circuit breaker mounted usually on the frame not far from the battery.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
