Dutch_12078
Sep 14, 2015Explorer III
westernrvparkowner wrote:
Even if you came across a split duplex outlet that was wired where each outlet was on a different leg what difference would that make? There is no situation I can think of where it would make any difference since there is no reason to ever cross connect those two outlets.
I haven't seen them offered in awhile, but there used to an adapter sold, that was intended for generator use as I recall, that consisted of a block that plugged into both halves of a duplex outlet, and had a single 30 amp configured outlet. It couldn't supply 30 amps of course, but the paralleled contacts did provide more contact area to minimize overheating. In a split duplex/split phase configuration, plugging such an adapter in was guaranteed to set off fireworks, or at least pop the breaker.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
