MFL
Aug 23, 2023Nomad II
bgum wrote:
I can't figure out how you're doing all that on 15 amps. That circuit is over loaded.
^This...running the AC alone on a 15A circuit, would be a heavy load. Any additional electrical load should trip the breaker. The converter charger is likely overloading, so helps to shut it off.
To be there that long, a 30 amp circuit, with 10/2 minimum wire would be a wise investment. I used 8/2 to run 75'.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
