MFL
Aug 24, 2023Nomad II
ScandentTrek wrote:MFL wrote:bgum wrote:
I can't figure out how you're doing all that on 15 amps. That circuit is over loaded.
^This...running the AC alone on a 15A circuit, would be a heavy load. Any additional electrical load should trip the breaker. The converter charger is likely overloading, so helps to shut it off.
To be there that long, a 30 amp circuit, with 10/2 minimum wire would be a wise investment. I used 8/2 to run 75'.
Jerry
We haven't had an issue with the breakers tripping. Our AC unit is as old as the trailer and fairly small.
How would using too much AC power (not enough to trip the breaker) cause the converter charger to overload? I would think the breakers (in the house or in the trailer) would trip first before any kind of overload could occur.
Maybe I should have said converter is overworking, possibly failing? In any case, a 15 amp circuit is not a good choice for full time living, supplying power for AC, microwave, toaster, coffee machine, hair dryer, etc.
CB ground issue, battery issue, converter issue?
Jerry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
