ScandentTrek
Aug 25, 2023Explorer II
enblethen wrote:
I hope you mean "17-volts" not amps!
120-volt 15 amp should not have any effect as long it is good solid 120-volts.
Did you read voltage output with battery disconnected?
Did you call Best Converter for their input?
Yep, I just read 16.8v from the converter (blue wire) with the battery disconnected. With the battery disconnected, the battery recharge wire (red) is reading 10v.
I Know it's not supposed to be that high and that indicates a problem.
Also, when I tested the converter just now I could feel the heat coming off it and realized the fan wasn't running, which is weird because previously it seemed like it was Always running. The metal is Hot to touch and the fan won't come on. That might be the last nail in the coffin of this troubleshooting series.
Folks, I think I'm gonna need to do that $300 converter replacement after all. We got 3.5 good fulltime years out of the original 1997 model, I guess that's the best we could hope for.
I contacted BestConverter but haven't heard back yet, thanks for the recommendation!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
