mike-s
Jan 11, 2017Explorer II
Wiring fuses in parallel, as you describe, is not proper. You're correct that it could allow up to a 30A draw, which the wiring is unlikely to be rated for. It should be fixed.
Wiring fuses in series (along the same circuit) is fine.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
