DrewE
Jan 11, 2017Explorer III
There are times when fuses are used in parallel, usually because it's less expensive than getting a single larger-capacity fuse. One common example is the main ("reverse polarity") fuses on converters, which are often two or three fuses ganged in parallel. I don't think it's ever a best practice, but it can be an acceptable one under the right conditions.
What you're describing definitely does not sound normal or correct. I would guess that the lights and the awning were meant to be on separate circuits but somehow the positive lines got connected together somewhere.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
