dirtdivaca
Jan 11, 2017Explorer
Rolling Condo wrote:
A possible scenario would be where the power awning requires more amperage than one wire can carry. Therefore they have doubled up on the wiring, each wire would carry half of the load. From your description there are in parallel and not any shorts as the fuses would blow.
But if it required more amperage, why does it still continue to work if I disconnect one of the fuses? It seems it would require both fuses to be connected at all times to operate the power awning. I was told the awning doesn't require more than 15 but maybe I need to find the specs for that awning to confirm. Maybe I'm missing something.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
