westend
Feb 08, 2017Explorer
I'd bet a doughnut that the awning is powered by the light circuit even though it has it's own fuse location. If the Mfg's guys wired the awning from the light circuit, when you remove a fuse, there will still be power available through the other circuit.
The first place I would look would be the outside scare light fixture to see if the awning motor's power wire is attached to that fixture.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
