KimandChris
Mar 05, 2014Explorer
Artum Snowbird wrote:
What you should do is turn off the main power, and then take a screwdriver and tighten each hot wire on the breakers, and each and every white wire on the return buss.
Done, everything is good and tight in the breaker box.
Got hold of Northwoods (maker of of Arctic Fox) tech line. They say there is one GFI plug to do both circuits. Not sure how that is possible. Can anyone confirm that a gfi plug can protect anything on a separate breaker?
I have verified I have power coming out the new breaker. Chasing the wire to its next stop is proving difficult. Wish I had a wiring diagram.......
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
