Harvard
Apr 28, 2015Explorer
IF (big IF) the Honda (or any generator) chassis should come in contact with Earth AND not be Ground Connected to the 3rd prong RV CHASSIS/GROUND then ANY OTHERWISE NORMAL RV is going to attempt to raise its skin voltage to 1/2 way between the L1 Voltage and NEUTRAL via capacitative coupling between the L1 and NEUTRAL circuits in the RV when measured to said EARTH. IMO.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
