Salvo
Apr 29, 2015Explorer
You're right, the Honda is neither grounded nor bonded. The Honda ground is floating (no electrical connection). Since you only use the adapter for the gen, it makes no difference if the ground pin is broken off. Your gen is safe to use.
Ron3rd wrote:
The Honda genny is not grounded so what issues could arise using the broken dogbone?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
