salem's avatar
salem
Electrical Question
I've learned on this forum to plug my extension cord into the trailer before plugging the other end into the wall outlet, like when I'm in my driveway . (to avoid arching) Makes sense, and doing it that way is now just habit. Next question: Does it matter when you turn the battery disconnect switch back to the "ON" position in this scenario? Never really even thought about it till this morning when I was plugging in to cool the frig for Friday's trip.
    The only way "arcing" can occur when you plug a cable into any source feed is if there's a load on the circuit - i.e. no load = no arc. Ideally everything should be off when you plug in but in reality there often is some load, so if your battery is connected to the converter the latter will instantly see the former as a load and depending on it's state of charge may present a significant load on the system. Ideally you would turn your battery disconnect switch to the off position before plugging in to avoid this but I'd bet most don't. Since I use an EMS to protect the trailer's electrical system this entire point is moot as the EMS won't pass on power to the trailer anyway until it's predetermined delay time, either 15" or 136", has passed.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
