ginaseven wrote:
I plugged in to 110 tonight to turn the fridge on and have lights to start packing.
12volt lights do not come on either.
How long was it unplugged or since you ran generator or engine? I hope it is only the 12v disconnect but suspect you have run batteries down. You might have killed them if left depleted long. As others have said. Start with the 12v disconnect switch. it could be as simple as that. If not then put a voltmeter on the batteries. Do you know where your converter is? Use the voltmeter on the output of the converter. post results.
