wnjj
Mar 18, 2019Explorer II
Slow heating with a normal resistance element means there is resistance somewhere else in series. As mentioned above, a bad switch switch would do that. So would a poor connection anywhere between the power source and element (i.e. thermostat or overprotection device). If you try running it again, search for something hot. Alternatively, ohm out all of the connections with power disconnected.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
