Old-Biscuit
Mar 18, 2019Explorer III
Remove the cover above gas valve where the 2 sets of t-stats are (Push to Reset Cover)
Left side is the 120V AC set of t-stats
Check the black wires/connections
The drawn pan is punched out and edges rolled inward...but they are sharp and the wire insulation can get cut up causing burnt insulation and bad connections
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
