RVhiker's avatar
RVhiker
Electrical theory question...
Let's take as an example 50AMP RV service. A voltmeter between the two hots shows 240 volts, between one leg (or the other) and neutral shows 120 volts.
My question concerns what happens when each hot is connected within different circuits to the neutral to provide 120 volts from each hot. The electrons in the neutral alternately flow in one direction from one hot and in the other direction from the other hot. Why don't those oppositely flowing electrons collide and go boom? Or cancel each other out?
So, the bad news is that I don't understand something or a lot of stuff. The good news is that I don't do serious electrical wiring.
Could someone explain how a neutral functions with differently phased hots?
  • When properly wired off the same source the two 120 volt legs are in different cycles. The transformer is wired in series with neutral being in the center point of the two coils.
    If the two were off different sources, there would be issues on the neutral.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
