allen8106
Nov 25, 2014Explorer
Jack,
While definitely no expert in my humble opinion as long as you have the 7 pin connectors you should just be able to what you are thinking of. The #4 pin is for 12 volt charging. As long as you have a wire hooked to both #4 pins you can plug the connectors in as you suggest. My only recommendation would be to up size the wire by two wire sizes.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
