Heisenberg.. There is a lot of stuff I knew how to do when I was in school I've not done much of since.. Still, there is a lot I still can do.. But not all of it.. I'd have a problem with some higher Math functions now days without doing research.
Page 2: You are right, An electrician **SHOULD** know how to go to the code, but the question is WILL HE? Or will he just ASSUME, one thing I was taught is how to remember the spelling of ASSUME.. I will not tell you how but I will hint.. -U- Think about that.. The electrician ASSUMES it is a 240 volt outlet.. Never mind it says 125 volts max right on the box and on the outlet itself, he ASSUMES, he does not read.
