pianotuna
Aug 08, 2020Nomad III
So long as you are at 107 volts or higher you may be fine.
I would consider tightening all the connections and using some deoxit on the wire and plugs. Make sure the tines are bright and shiny.
My 13500 starts out at 1300 watts and can rise as high as 1900 watts depending on how hot the weather is.
