jodeb720
Aug 08, 2020Explorer
I had my 5er out in front of the house a few weeks ago
I put my volt meter in a few of the outlets and found it between 120 and 121 consistently.
I turn on the AC and it dropped immediately down to 112 and hung in there, but as time went, the voltage dropped to 109, then 108.
That's when I switched it off.
I had a roll of 12gauge wire in the basement, unrolled it out for the 35' I needed put a couple of 20amp rated plug heads on it and connected the 5er's dogbone to the 30 amp plug and tried again.
The voltage started out exactly the same - 120-121, but as the AC started to work harder, the voltage did drop but only down to 113 - 112 and stayed there.
Bottom line, the 12gauge extension cord which is 50' long wasn't able to handle the current needed by my ac.
Now, I know there's some out there who will tell me that's not legit - and they are correct, but for an emergency, and not wanting to damage my AC unit, I'll go with it.
As it was, because the AC was on, I finished reassembling the inside of my 5er after a major repair and we were able to use it for the weekend (first time in 8 months).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
