azrving
Aug 09, 2020Explorer
Timeking wrote:
I never plug my RV directly into any outlet at a campground; I use a Progressive Industries box that monitors amps, voltage. So I am monitoring voltage at the source NOT in or at the RV.
Based on what jodeb720 and azrving posted, my voltage drop is excessive. So that is now the question: Do I need to hire an electrician to run a dedicated line out to where the RV plugs in?
Also FYI, the AC has a slow start device so it doesn't kick in immediately and overload the generator when using that.
I am starting out at an advantage though, my source is 125 v so there’s a 5 v bandaid right there. I don’t think ive ever had a residence with 120 volts. Iirc Ive always seen 124 125 etc. When i built the house before this one it had a new pole and transformer Installed but don’t remember if i had a refrigerator issue or flickering lights but i called them and they adjusted the transformer and it was then about 124 v iirc
The house im in now has a transformer on the pole on the property that drops down to my outdoor shut off panel then runs into the house sub panel about 25’.
