azrving
Aug 09, 2020Explorer
I just checked the plug in the master, oops I mean “primary” bedroom which has a 8000 btu window ac unit and that plug is at 124.2 v with the window ac running. I have central air but the window unit pretty much carries the house even at 100 degrees out. Main ac is at 72 and probably comes on 6 or 8 times a day. 1900 sq ft house has been running about $140 a month. Bedroom window unit runs from 9 am to midnight and keep it set at 62 It has shut off at times and you can hang meat in the bedroom. Just some comparison info for the heck of it
I just checked my 30 amp RV plug at the full hook up end of the house right at the power pole and its at 124.5 with the window unit on and the rv ac down at the 140’ away end running
